tosh wlt screen cleaning
Discussion in 'LCD & LED LCD TVs Forum' started by michael 38, Apr 24, 2007.
Tags:
  1. michael 38
    michael 38
    Mar 1, 2007
    978
    28
    +37
    i know there are other answers on the forums but im still not sure bought a lcd tv cos there not supposed to attract dust but like a crt but mine does i used to clean my old crt screen with the brush on the vac cleaner but i dont think its a good idea on a lcd, toshiba told me to use a dry lint free cloth but all it does is spread the dust around, has anybody used a cleaning spray on their wlt 68, empire direct sell a spray + cloth for £20 but tosh dont reccomend it.
    i am worried cos my other half cleaned her dell flat screen moniter with some detergent and had it coverd with permanent smears, you would have thought manufactures would have made lcd tvs with screens that are easyer to clean and more robust
  2. Gadget Freak
    Gadget Freak
    Apr 8, 2006
    687
    London
    +73
    Don't quite understand this 'cause my Tosh (wlt) doesn't attract any dust at all, at least the screen doesn't. I just use a microfibre cloth bought from tescos for a £1. If theres a stubborn mark just wet the cloth a little with tap water and rub gently.
