Tosh With Shadows
Discussion in 'TVs' started by scotstevie, Jun 25, 2003.
  1. scotstevie
    scotstevie
    can the shadows that have appeared on the left and right sides of my new 36"tosh be repaired,and has anyone else had this fault from their set.i would be keen to know
  2. shaunthedude
    shaunthedude
    I had a Tosh RP set and the right of the screen was a sort of sepia colour, mainly visible on b/w films. This is common to tosh tvs, IF its the same fault as your that is
    cheers
    shaun
  3. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Does it look as if the sides of the screen are dirty when you view a light coloured background? If so they have almost certainly been there are all along. Unfortunately it is "feature" of a couple of Tosh models and was something i was unwilling to live with. Try doing a search for:
    Tosh* AND sides
    That should throw up quite a lot of info.
