Tosh vs panny vs pioneer HDD DVD recorders
Discussion in 'Blu-ray & DVD Players & Recorders' started by nunew33, Jan 28, 2004.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Please correct me if ive got anything wrong
    Tosh:
    60GB, DVD RAM, no componant,
    Panny:
    40GB, DVD RAM, no componant, RGB in, PCMCIA slot
    Pioneer:
    80GB, No DVD RAM, no componant,
    Assuming I am happy with 40G min and I choose to live without componant and RGB in.
    The Tosh is the cheapest, why would I pay more for the others?
    What "key" differences other than those above have I not considered?
  2. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    I couldn't see any major difference ar advantages either which is why i bought the Tosh back in August. Most happy with it. On the recordings i've made from Sky or back up's of Vhs (which was pretty crap quality to start with) i can't see the results being much or any better if the Tosh had RGB.
    Panic
  3. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Hmm.
    Just thought, connectivity could be an issue. I was hoping to replace DVD player and VCR. But DVD is connected to Projector via componant, so no need to replace. IF I wanted to benefit from RGB out then I would need to connect to projector using scart->VGA which is being used by Sky. With no RGB pass thru, it would mean either sky or Tosh but not both, unless I went for Panny.
    Its going to be a mess!
  4. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Pioneer does RGB pass thru, just doenst record in RGB, which ive not found to be a problem
  5. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    does the tosh do RGB pass through?
  6. bobbles
    bobbles
    yes it does
    it has a splendid sat monitor function
    so you can use your dvd to record terrestrial or burn a dvd whilst still watching sky via rgb. Do you have standard sky or sky+? If you have standard sky you will have a problem with the tosh in that, as you are aware it does not accept rgb. Unfortunately standard sky does not output s-video so you will be left with pretty poor composite.
    You could however buy an rgb to s-video converter.
    If you have sky+ then I would definitely go for the Tosh no question. It is a fabulous machine.
    I did a quite long thread on this very topic. Listing all the pros and cons. it is probably on page 3 or 4 by now
  7. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Thanks bobbles. I have the grundig sky box which does have svid out! (must chage my kit list)
    Im half tempted to wait for a componant out model, but if one did come out id have to wait another 6 months before they droped to the tosh price.
    Theres no DV in either is there on the tosh?
  8. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Quick question for Bobbles.
    Up till now i've had normal Sky with no s-video. To-morrow , weather permitting , i'm getting Sky+ installed. Will s-video make a huge difference do you think connection wise from Toshiba to Sky box?
    Panic
  9. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    S-video will offer improved quality recordings over composite,which is presumably what you have been using
  10. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Thanx Phelings. Yeah i've been using composite till now , i'll nip out and buy a lead to-day in preperation although with all the snow around i'm thinking i'll get a call from the ariel boy saying install for Sky's off till next week :(
    Still that leaves time for some sledging on my day off :)
    Panic
