Tosh TV and SD220 DVD Help !!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by tobytyke, Dec 21, 2002.
  1. tobytyke
    tobytyke
    I've just purchased a Toshiba 32ZP18Q TV (well impressed too) and have linked my Tosh SD220 DVD player via component leads and optical digital audio lead to it.
    The only problem is I get excellent sound but no picture. Is there something else I've missed. I understand that these are the only cables required for such a configuration.
    Any help gratefully received 'coz it's doing my head in !
    :confused:
  2. bowenjones
    bowenjones
    Oct 24, 2002
    2,802
    Wales
    +446
    Have you set your dvd player to "video" and not "RGB"?
    RGB signal can only travel through the scart lead whereas
    component leads can only transport a video signal.
  3. tobytyke
    tobytyke
    The only problem is how do I get the DVD menus on screen since I can't get anything (apart from sound) from the DVD ???
    Do I need to temporarily connect via SCART and make the changes ?
    :confused:
  4. tobytyke
    tobytyke
    Thanks BowenJones for your help - it now works a treat !!!
  5. bowenjones
    bowenjones
    Oct 24, 2002
    2,802
    Wales
    +446
    No problem,
    Mind you, why are you using component leads when
    you would get a much better picture if you used a decent
    scart lead ?
    RGB produces a far superior picture compared to video and
    you can pick up a good scart lead from argos for under £15.
    There are better quality scart leads about such as one's
    from QED but you'd only see the benefit if you had a larger
    screen size.
    Oh, and bye the way,
    do you have composite inputs on your toshiba tv as the
    composite leads are supposed to give you the optimum
    picture quality although I can't confirm that because I don't
    have the input sockets on my philips 32" w/s tv.
    I ase an oxygen free scart lead which I bought from argos
    a couple of years ago and I'm more than happy with it.
  6. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    Bowenjones - I'm afraid you're a little confused. Toby - keep the YPbPr component video connection.
  7. bowenjones
    bowenjones
    Oct 24, 2002
    2,802
    Wales
    +446
    tobytyke,
    Forget my last reply as I have had a little too much to drink
    and therefore got my components and composites in a twist!!!
    If you do happen to get a scart lead let me know how the
    picture compares to the component set-up you have as I read
    a review stating that the component quality isn't up to scratch
    on the 220.
    My apoligies again for the alcohol influenced stupidity that was
    my last reply...hic!
  8. bowenjones
    bowenjones
    Oct 24, 2002
    2,802
    Wales
    +446
    MarkB4506,
    I realised my mistake as soon as I posted so I tried to get
    in there and hide my shame but you beat me to it!!!
    A warning to all forum users.....
    DON'T USE WHILE DRUNK !!!
  9. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    By seconds it seems!!
    :p
    Merry Christmas
  10. ajoshi
    ajoshi
    I would like to find out if RGB is better then a set of components. As I am looking to buy a new tv based on that decision. the rest of my kit i have already purchased.
    So far I have got Monitor Audio silver av package (9i, 4i and 12i) with yamaha az1 amp and denon 3800 dvd player. The tv choice i have got is either Tosh (36zd) with components or Phillips (36" 9607) which dosen't have components.
  11. bobbles
    bobbles
    component inputs are without a doubt better than RGB IMO but i am no expert
