Tosh TV and DVD sound issue - help !!!
Discussion in 'General TV Discussions Forum' started by DanT, Apr 20, 2003.
  1. DanT
    DanT
    Nov 13, 2001
    herts
    Hi, i hope someone can help me. I have the following set up:-
    Tosh 42WH18B television
    Tosh SD-420E DVD player
    Problem:- I cannot make the sound come out of the televison's internal or external speakers above a pretty low volume. I have tried all three scart sockets on the TV, the optical cable linking the TV and DVD, composite connections, all the menus that i can think of on the DVD and TV. My video and TV cable work fine, both usingscart connections - so what is limiting the DVD volume ? I have to raise the volume to 65 to get reasonble volume and it is overwhelmed then by a loud hiss. Cleary something is not right !!
    Surey with all the connections and money laid out i don't need a seperate amp just for the DVD ??? My video, gamecube etc are fine so i am thinking it is a DVD player issue but.........help !!!
    many thanks
    Daniel
  2. chris_onewildla
    chris_onewildla
    Assume that you have assigned the optical input to the correct scart input? I run a tosh sd220 through my 50wt29 using the optical input for sound and component video for picture with a full set of external speakers and find a volume level of about 30-35 is normally o.k
