Matt F
Established Member
With the imminent launch of a new 36" CRT Toshiba (36ZD26P) that offers progressive scan - http://www.hed.co.uk/ienav3/showproduct.asp?CAT=50&PID=3220 , it's very tempting to get an SD900e to go with it from leconcepts.
Now, Leconcepts say their multi-region SD900e outputs progressive scan on both NTSC and PAL DVDs and they mention "3:2 Pulldown" - can anyone tell me what this means?
Presumably, if I connect the SD900e to the 36ZD26P using the component video leads and then all DVDs will be replayed in progressive scan?
Finally, a quick question on CD playback - I've heard that the Arcam DV88 has the edge on the SD900e for CD playback but, presumably, if I use the DACs in my TAG AV32R for CD playback then it's just going to come down to the quality of the transports and the difference should be negligible?
Thanks for your help.
Matt.
Matt.
