Tosh SD340E
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by rob27, Nov 23, 2004.
  1. rob27
    rob27
    Nov 2, 2004
    161
    +9
    Not sure if this works but got it from dvdrhelp.com
    Region code hack posted by Stilgar, October 29 2004:
    Codefree via remote control:
    -open the tray
    -type 2403960
    -press enter to cycle to region 9
    -close the tray
    -turn the player off
    -turn it back on
    Works also with RCE!
  2. Fat Tony
    Fat Tony
    May 1, 2004
    640
    +20
    Thinking about one of these R2 players for my mum - does anyone know if this hack works?
    Also, is this a permanent hack or does it have to be entered each time?
  3. videonasty
    videonasty
    Feb 12, 2004
    2,259
    West Midlands
    +39
    I'd be interested in this hack, as I've just had one of these? :thumbsup:
  4. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Richer sounds multi region £79.99 sd340e
  5. nburman
    nburman
    Just tried the handset code entry method to make the sd340e multiregion and it worked. Tried playing a region 2 disk and then a region 1. Both played. I didn't try the region 1 disk before (a mistake on my part), so can't be absolutely sure of the state of the sd340e before applying the code.
  6. allengn
    allengn
    Sep 6, 2004
    104
    Sutton Coldfield
    I also applied this hack to my 340e last night. Tried a Region 1 disk beforehand, came up with an invalid region message. After hacking, it worked fine.
  7. MattMcSpirit
    MattMcSpirit
    Apr 7, 2004
    113
    Bracknell
    +4
    So the remote hack definately works for the 340e? I have seen one for £69.99 R2 and £79.99 MR. Dont wanna get the R2 one and the hack not work!
  8. Slapnut
    Slapnut
    Has anyone tried this on the SD-240? Are there any other hacks available for the SD-240? Thanks...
  9. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Anyone else tried the 340e hack bit reluctant to try.Dont know why, it cant break it .......can it?
  10. allengn
    allengn
    Sep 6, 2004
    104
    Sutton Coldfield
    Well, my DVD is still working (playing Region 2 discs) after applying the hack. But as I only have 1 Region 1 disk, which is now wrapped as a Christmas present, I can't yet confirm whether the ability to play Region 1 discs is still functional.
    If no one else can confirm, I will post again after Christmas.
    However as no-one appears to be saying it doesn't work, then I would infer it does.
  11. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Handset hack works spot on.
  12. allengn
    allengn
    Sep 6, 2004
    104
    Sutton Coldfield
    Yep, mine's still working too.:clap:
  13. ediee96
    ediee96
    THANKS FOR THE HACK THIS HACK WORK ON MY DVD PLAYER TOSHIBA SD-K741
  14. RedRasper
    RedRasper
    Dec 7, 2004
    37
    Just to add in I tried it on my 340 and it worked a dream! PLays everything fine!
    Am interested to see what other codes you can type into it though!
  15. bigfatsi
    bigfatsi
    Jan 24, 2005
    120
    19
    Teesside
    Just tried it on my 240e and it works great. Cheers!
    Bigfatsi
  16. rondun
    rondun
    Hi - can anyone confirm if this works on R1 RCE encoded disks?
    thanks
  17. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    yup! :)
