Tosh SD241E optical digital out problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lunchie, Mar 6, 2005.
  1. Lunchie
    Lunchie
    Jan 7, 2005
    4
    I was given the subject player as a present, with the only stipulation I gave to the person buying it wa that I needed optical output, so that I could continue to use my Yamaha VS-10 surround system that I bought a while back. I used to just use my PS2 with it which worked fine, as I needed the VS-10 built in 5.1 decoder.
    Trouble is I'm having problems getting the digital output to work. Are there any tricks or setting that I'm missing? I don't see any light light coming out of the optical socket. So is just bust, and I need to change it or is there something I can look at before taking it back.
    Also the Tosh has a decoder built in, so what happens when the digital signal is sent to the Yamaha, also with a decoder?
  2. Lunchie
    Lunchie
    Jan 7, 2005
    4
    Anybody?
    TOP
