Quantcast
Tosh sd220 lop sync prob
Mugged
Hi can anyone help had this tosh for a while now but only just tried playing a vcd/svcd disk and noticed that the lip sync is way off, when playing these disk can i do anything to put this right ?. Or is it time to get yet another dvd player.
Regards Mugged................
Mugged
Thnx for your reply just tried but not working just get no audio at all when i do that damm dvd player.
Mambo
When you press angle it switches the audio track (strange I know) if you switch to audio track 2 (no sound) then back to 1 by pressing angle, that should cure the lip sync.
Mugged
Hi thnx again your right i worked it out in the end cheers.
Similar threads
