Tosh SD200E -> 42PD5200 No component signal!!
Discussion in 'Plasma TVs Forum' started by ziglar, Nov 17, 2004.
  1. ziglar
    ziglar
    Dec 1, 2002
    348
    Berkshire
    +19
    I used to think I understood a little bit about connecting AV bits together but now I'm not so sure ... I just bought a shiny new 5m component cable and connected my SD200E to my shiny new 42PD5200 and waited for a fantastic result; No such luck - I get 'No sync signal' whether I use AV1 or AV2.
    What am I doing wrong. The TOSH video output only has 3 choices 'video, s-video and RGB' and it's set to RGB. Output via the scart to scart is OK.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    RGB on scart very likely disables the component output, it's pretty normal except Denon and Onkyo, and then only a fair way up the range.
  3. ziglar
    ziglar
    Dec 1, 2002
    348
    Berkshire
    +19
    what a little star you are MAW. Set the TOSH output to video and lo & behold the component signal is out.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I'm just paid to know these things.
  5. ziglar
    ziglar
    Dec 1, 2002
    348
    Berkshire
    +19
    well I just hope that they pay you obscene amounts of money.
  6. mray
    mray
    Feb 16, 2004
    2,771
    83
    London
    +234
    Does setting it to s-video give a better picture?
    I thought when using component, that was the option you're supposed to use.
  7. ziglar
    ziglar
    Dec 1, 2002
    348
    Berkshire
    +19
    :oops: - sorry, I lied. It is set to s-video not video.
  8. mray
    mray
    Feb 16, 2004
    2,771
    83
    London
    +234
    Hey, no problem.
    When I conected my Toshiba I flicked between video and s-video and I couldn't see a difference. But then I can't see the flicker on a 50hz TV either!
