Tosh SD-520 Progressive question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jayb, Nov 10, 2003.
  1. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
    I have a Tosh SD-520 MR DVD player and a 32zd26p tv
    when I bought the set up all my DVD's were R2 So progressive scan was not an issue. To check PS I borrowed TTT which was a NTSC copy (I dont buy or condone copies). when I played this the picture was spot on ,when I pressed the Progressive Toggle button on the remote it turned off the progressive mode and the picture was much poorer.
    I have just bought my first R1 DVD from DVDsoon (Finding Nemo), when I play this the picture looks good but when I got up close I could see some Jaggies, I assumed that PS would eliminate this and maybe thought that it had not come on automatically so pressed the toggle button,which put up the little stop sign in the top right hand corner of the screen
    So is the stop sign just telling me that I cannot watch this in progressive mode or is it telling me I cannot come out of progressive mode?
    As I said the picture does look good and the jaggies are only noticable if I sit closer to the screen. Although now I know they are there I do notice them when the action hots up
    As this is my first R1 I have nothing to compare it to
    Any suggestions would be much appreciated....:smashin:
  2. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    It might want you to stop the movie first before allowing you to switch between Interlaced and Progressive Modes (my Tosh SD900 allows you to switch whilst the movie is playing). A couple of things to check. Have you got the switch on the back of the player set to Progressive? Make sure the player is set to AUTO so it selects between NTSC and PAL automatically.
    Check the Progressive Scan Conversion is set to AUTO as well. Sometimes it's worth trying the different modes, FILM, VIDEO. FILM works best for most stuff or just leave it on AUTO.
  3. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
    Thanks Jase
    I have just gone through your check list and discovered the switch on the back was to blame, I must of changed over at some point after trying TTT.
    I thought it looked good before but now....:eek: :eek: it looks amazing
    Thanks again Jase and now I know why you all rave about progressive scan even if you only have a 32" it makes a big difference....:smashin:
    Also big sigh of relief that I didn't waist £2000 on my set up...:D
  4. bash
    bash
    Nov 10, 2002
    2,364
    London
    +319
    This is good news, Im looking to get an SD520 as soon as I get enough cash to partner with my 36ZD :D
  5. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
    bash
    If you are watching NTSC DVDs it is well worth buying the 520, I did a lot of research on the forums and although some people do prefer the more expensive progressive players, not many could fault the quality you get from the £200 multi regioned player
    Probably even cheaper now....:D
  6. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    You can pick up the later SD530 for 200 quid now. Also has PAL Progressive if your TV supports it. :)
  7. bash
    bash
    Nov 10, 2002
    2,364
    London
    +319
    afraid NTSC only on my TV, the 520 should match it perfectly. It'll be finding one that'll be tricky!
  8. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
