Tosh SD-150E - perhaps a stupid question
Discussion in 'Blu-ray & DVD Players & Recorders' started by RMCF, Sep 2, 2005.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,405
    +735
    I noticed the spec for the SD150 said that it has PAL Progressive Scan.
    Does this mean that if you get the machine multi-region that it won't play NTSC in Progressive Scan?
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Correct pal progressive only.
  3. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,750
    On AVForums
    +568
    according to what hi-fi mag, it can do ntsc prog scan also.
