Tosh RXS32 component question
Discussion in 'Blu-ray & DVD Players & Recorders' started by F G Evans, Jan 17, 2005.
  1. F G Evans
    F G Evans
    I recently purchased a Yamaha RDX650 applifier which upconverts a composite signal into s-video.
    At present i am using my x-box with an s-video lead straight into the front on my Tosh RPTV. There is no benefit therefore by connecting the x-box to the amplifier (obviously apart from the sound)
    My recorder is connected by component to my TV and i have my Humax freeview boxplugged into the recorder through its RGB connection.
    Now i know that the recorder will output the Humax signal through the component leads - so i assume the recorder is converting the RGB signal to component.
    However if i connect the x-box into the front s-video connection on the recorder and select it will that also be able to be pushed through the component output to the TV.
  2. F G Evans
    F G Evans
    Anyone?
  3. F G Evans
    F G Evans
    surely someone has some idea about this
  4. kitschcamp
    kitschcamp
    Sep 13, 2004
    245
    28
    Australia
    +63
    Personally I see no reason why not. If I feed it S-video, composite or RGB via the scarts it quite happily outputs it as component. I don't see any reason for the s-video jack to behave any differently. Try it.
