Tosh RP - Which component to component lead?
Discussion in 'Televisions' started by matt janes, Dec 3, 2001.
  1. matt janes
    matt janes
    Any Toshiba owners using component to component? What lead are you using? I've heard mixed reports about need to spend £10 vs £50 and wondered what the results were like for you owners. Some say Maplin for a £10 lead but something tells me it'll be crap...
    Gracias.
  2. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    I'm using a 3M cable from Chord (£85 I think). Seems OK, although I can't honestly see any difference between it and RGB scart.
    John
  3. CRVNOS
    CRVNOS
    I'm using a £1.50 one of the market and its fine, better that the scart i was using but that was only 50p from the same market !! :)
  4. Guest
    I spent £75 on some cables for my Tosh - I could not tell the difference between them and my IXOS gold SCART RGB connection. In fact, I preferred the RGB and the cables sit doing nothing in a box ! I guess it depends somewhat on the TV, the source (DVD manuf/model)....
    Just because you have component input - doesn't mean they will necessarily be the best option. Many will disagree.....perhaps I have low-res eyes !
    Daz
  5. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    948
    Scotland
    +18
    Only difference I noticed was improved colour saturation on NTSC stuff.
    I use it [when I can] because it frees up the RGB scart for my Digibox
