Tosh RP Owners: Is This A Fault??
Discussion in 'TVs' started by Meldrew_Lives, Dec 3, 2001.
  1. Meldrew_Lives
    Meldrew_Lives
    Sep 18, 2001
    24
    Farnham, Surrey
    Had a new 46WH08B delivered 3 weeks ago and spent some time getting the settings right using all the good advice on this forum.
    Everything has been fine until the last couple of days. When I first switch the set on after it being off for a while (e.g. overnight) the convergence has gone wildly out. It gets a little better over the next 10-15 mins and then suddenly everything is OK. It is almost as if a switch has been operated.
    Since it was not previously doing this (and I haven't been messing with the settings for a while) I'm wondering whether I need to get on to a service engineer.
    Anybody else had/having this experience??
  2. CarlB
    CarlB
    Jan 8, 2001
    1,108
    Godmanchester, Cambs
    +96
    It takes about 45mins for the set to warm up, and your convergence may be out during this time.
  3. Guest
    As a rule, leave your set on for at least 40mins - 1 hour BEFORE even playing with convergence settings. Following this, don't be tempted to change them again until the set has warmed up, you should find things start to come back into focus without you needing to fiddle anymore.
    I found that the set gets better after it has been "run in" for a while...so you probably don't need to reach for the engineer phone number just yet !
    Daz
  4. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Yes, i've noticed this too with the 40WH08B.
    Also it helps (enormously) if you have good colour vision for the convergence set up.
    I thought I had it set up OK, until I got a second opinion from somebody with normal colour vision.
    I am colour blind on reds and greens and I was way out with the convergence.
