Tosh RGB left Shift
Discussion in 'Televisions' started by jblandford, Feb 9, 2003.
  1. jblandford
    jblandford
    Mar 4, 2002
    46
    I have a Toshiba 32 widscreen 100hz scan 32WB98D
    I have a panasonic Sky box that when I put it into the RGB output, the picture shifts to the left alittle and I lose part of the left hand side. Put it to PAL and it is OK.
    Anyone else had this and how do i cure it. The boys on the Sky forum sugested I ask here.
    Many thanks in advance
    JB
    :confused:
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    republic of ireland now
    +56
    Find out how to access the service menu of your TV, ask here, and u can adjust the shift yourself.
    gb---
  3. mjn
    mjn
    May 24, 2001
    17,967
    Herts, England
    +4,938
    Firstly, what has PAL got to do with it??
    You'll find that switching yout Tv into RGB input will cure it.
    If i use the composite input, my picture moves to the left, switch to the RGB input, the picture is correct.
