Tosh RDXS34 + Bush DFTA3 STB
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steve Mario, Jul 3, 2005.
  1. Steve Mario
    Steve Mario
    Hi All
    Just bought this and v pleased, but struggling to get any connection established via the IR link with a Bush DFTA3 STB. Tried all listed codes but no luck
    I seem to get an occasional reaction so wondering if I have a positioning problem as well as/instead of a code one!
    Anyone had any luck with this? If anyone has succeeded please let me know the code, otherwise what budget STB's work? I'll just get a second one to use with the Tosh
    Steve
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Not a budget box, but I've got it "working" with the Sony VTX-800 (code 1526). Though it doesn't change channel when I use the up/down channel buttons on the remote. But it does the important thing, which is I can set a timer and using the "Sat Cont" button I can specify a channel on the Freeview box, and the recorder will change the channel.
    Mark
  3. Steve Mario
    Steve Mario
    Thanks Mark
    Spoke to Toshiba Tech Support, who tried hard, but apparently don't carry a list of supported units. They did come with the following nugget, don't know if it's been posted elsewhere. Apparently all IR codes are sourced by Tosh from Gemstar, the VideoPlus+ company. They gave me a help line number but doesn't seem to be correct. Anyone know any other info sources?
    Steve
