Tosh RDXS32 - noob asks stupid question re camcorder transfer
Discussion in 'Blu-ray & DVD Players & Recorders' started by Geoggy, Feb 28, 2005.
  1. Geoggy
    Geoggy
    Oct 23, 2002
    2,790
    in that number
    +299
    Sorry - i've looked for this but cant find it.
    I want to transfer my mini DV camcorder tapes to the HD of the tosh to edit / burn.
    Can someone point me to the cables i need to connect them together?
    Thanks (and apologies - im new to all this)
    G
  2. MarkhamPete
    MarkhamPete
    I had a Toshiba briefly for a week, but now I have a Pioneer. I went to record my minidv tapes to the hard drive and realized the recorder uses a different firewire than for a PC. The recorder in/out is the same size as the camera's in/out. If the Toshiba is the same, then you would need a 4 pin to 4 pin firewire cable. The typical PC firewire cable is 4 pin to 6 pin.
    Hope this helps.
  3. Geoggy
    Geoggy
    Oct 23, 2002
    2,790
    in that number
    +299
    thanks - so can someone confirm its definitely a 4 pin firewire post on the TOSH?
  4. MarkhamPete
    MarkhamPete
    You should be able to look at it and compare it with the in/out on the camcorder. Maybe google images of 4 pin firewire and 6 pin firewire and compare that way - that's what I did to find out what cable I needed.
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
