Tosh RD-XS32: Checking Recording Rates
Discussion in 'Blu-ray & DVD Players & Recorders' started by L00py^, Jan 28, 2005.
  1. L00py^
    L00py^
    Sep 23, 2004
    129
    If I record say a film last week, how can I check at what rate I used. If I press the display button twice, just get a blank on recording quality. ie I wanna use the same rate to record onto DVD?
    Also if I record on hard disk using LP 2.2. I then first recorded from hard disk to DVD at SP 4.4 by mistake. I then deleted this programme on the DVD and record onto the DVD at LP 2.2. I noticed the amount of space left on the DVD had gone down. So does this mean in the first instance it had recorded in SP 4.4 mode? How can you go back up in rate on copying?
  2. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    From either the content menu or while playing, choose Title Information from the Quick Menu and it will tell you the bit rate used.
  3. El_JimBob
    El_JimBob
    Dec 4, 2004
    115
    16
    Handy tip if yr unsure what bitrate yr using to record with - pressing the 'FL SELECT' button on the remote will eventually bring up an indication of bitrate on the LCD display.
    Im using it alot at the moment to make sure i don't balls things up when it comes time to archive....
  4. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Also If you use hi speed dubbing the rate always remains the same
  5. L00py^
    L00py^
    Sep 23, 2004
    129
    Thanks for your replies, yeap I assumed if you used high speed dubbing the rate would remain the same, so was surprised to see the two differences in remaining DVD space.
    So when you high speed dub, what should I have my DVD recording setting at, the section where you can pick five different settings. Also whats "-----" mean, it has no setting stored at all?
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,224
    Warwick
    +2,268
    What type of DVDR were you recording onto? With DVD-R whilst you can delete titles you do not get the space back. Likewise with DVD-RW (until you format).
  7. L00py^
    L00py^
    Sep 23, 2004
    129
    It was DVD-RW, so if I record a title onto a RW type disc, then delete it, I need first to re-format the disc again before I will have a blank 4.7gb disc?
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,224
    Warwick
    +2,268
    Yes - that is correct. Effectively DVD-RW operation is just like DVD-R - you fill it up and then finalise it. The only difference is you can format and start again.
    For your information DVD-RAM operation is somewhat different - that will allow you to delete a recording and recover the disc space- as it uses VR mode (same as the HDD).
  9. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    Only when the last item is deleted on a DVD-RW Video mode disc is the space given back (this is so it remains compatible with DVD Players). If you had items recorded after the one in question you deleted, the space will not get given back.
    Space is totalled up from the end, so if you had 20 minute, then 10, then 30 minute recording and deleted the middle 10 minutes, your freespace doesn't increase, however when you delete the 30 minute title, you would then get back the 30 minutes, and then the 10 minutes.
    Don't forget you can also unfinalise DVD-RW Video mode discs, this can be handy when you want to add more to the disc later.
    None of the above is possible with DVD-R as that is write-once, so no space can be recovered and once finalised, it is final :)
    Regards
    Philip
  10. Rasczak
    Rasczak
    Apr 3, 2002
    21,224
    Warwick
    +2,268
    Go on then Philip - describe how this is done on the Toshiba RDXS32 :laugh:
  11. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    HI
    I have no idea off the top of my head so I suggest the original poster has a play about, it's half the fun of these things isn't it, having a play?
    Regards
    Philip
  12. L00py^
    L00py^
    Sep 23, 2004
    129
    I had two 10 minute programmes on the disc and was un-sure if any wasted space so I formatted the disc. Recorded the first programme onto the disc and got some message. Now its says disc is write protected, I cant copy any more stuff onto it, or even format it again?
    Any advice plz?
  13. Rasczak
    Rasczak
    Apr 3, 2002
    21,224
    Warwick
    +2,268
    Format and try again :) If it still doesn't work we'll take it from there - can you tell us what the error message was?
  14. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    Sounds like a media problem? What is the media brand?
    Write protected messages often mean the recorder has experienced too many errors writing and so decides it is safer not to do anything more with the disc. Check the disc for dust, fingerprints etc. If possible try another disc before deciding it is a problem with the hardware.
    If the recorder is refusing to format the disc again then there little you can do unless you have a PC Writer or other hardware you could try erasing it on. Just assume the recorder knows best and the disc is bad, and try another.
    Regards
    Philip
  15. L00py^
    L00py^
    Sep 23, 2004
    129
    Yeap other discs work fine. All disc are TDK 1-2 DVD-RW ones.
    When I try and format, it goes to 100%, the just get a message saying " This DVD cannot be formated"
    If I press content, get a message saying " This operation cannot be performed with pre-recorded content"
    I do have a PC with a cd-burner could I use that to try and format the disc?
  16. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    It would be worth doing a full erase on your computer and then trying again. It could be bad sector very early on in the disc, unfortunately with DVD Video the recorder can't use any defect management to repair that damage, as doing so would render the disc incompatible.
    If you find a full erase still doesn't give you a working disc, pop it in an envelope back to TDK with a covering note explaining your problem and they will replace it, if you are lucky they may supply a little bonus in the way of a few more discs!
    Regards
    Philip
  17. L00py^
    L00py^
    Sep 23, 2004
    129
    Do I need to use any special software when erasing on my computer then plz?
  18. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    You can use any type of DVD burning software, just find the erase option, and go for the Full Erase, it should take around 30 minutes on a 2 speed DVD-RW.
    I wouldn't be surprised from your description of the problem for the same thing to happen again when you try and initialise the disc in the recorder, but it is worth a try.
    Best of luck.
    Regards
    Philip
  19. L00py^
    L00py^
    Sep 23, 2004
    129
    Doh my DVD drive is read only. I try and get some TDK freebies then :p
