Tosh RD-SX32 setup with Philips Digibox
Discussion in 'Blu-ray & DVD Players & Recorders' started by REByers, Dec 20, 2004.
  1. REByers
    REByers
    Dec 20, 2004
    12
    3
    Preston, Lancs
    Hi, Just got a Tosh RDXS32 this weekend and setup is going fine!!
    I have now come unstuck trying to get my digibox (a Philips DTR1500 box) to be seen via the RDXS32. I have connected the digibox to the Tosh via a fully connected scart lead, as per the tosh manual, but not matter what s-video, composit selections I make on either device nothing seems to persuade the digibox to be visable via the tosh box.
    The Tosh box is connected to the TV via a componenet RGB lead.
    Help!!!! :lease:
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I assume the digibox is connected to the Tosh AV2?
    Then select the channel on the Tosh to AV2 (from the remote)?
    Do you just get a blank screen?
    Mark
  3. REByers
    REByers
    Dec 20, 2004
    12
    3
    Preston, Lancs
    Yep, that's exactly how it's connected, and I just get the plain blue screen.
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Sounds like you've done everything right!
    Do you see a picture when you press the "Sat Moni" button?
    Mark
  5. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    I have a Thomson 2300 box similarly connected and it works fine.
    Thomson output AV1 to Toshiba AV2
    Toshiba AV1 to TV AV1
    In Initial setup menu of Toshiba, set AV2 input to RGB.
    This of course presumes that your Philips box and TV also have RGB out and in respectively.
    Cheers,
    Ray D
  6. jmontra2
    jmontra2
    I have one T.D.T. box machine too, mine is Philips DTR4600 and I've conected it via scart to the AV2 entry on the Toshiba.
    I've selected in the DTR4600 the RGB signal (in the instalation menu) for the TV scart connector, wich is connected to the AV2 in the Tosh, and selected too RGB in 'AV2 input' in the menu 'Inittial Settings'.
    I see the TV trought my projector using the components signal in progressive and the image is GREATTTT!!!
    Hope it helps!
    Jordi
    Barcelona
  7. REByers
    REByers
    Dec 20, 2004
    12
    3
    Preston, Lancs
    Just to clarify I've got AV1 on the Philips decoder connected to the TV AV1 in via an RGB scart.
    AV2 from the Philips box to Av2 onthe Tosh, via fully (all pins) connected scart.
    Tosh AV1 (RGB componenet out) to TV componenet in (AV4 on my Tosh TV).
    I get nothing when I hit the sat mon button.
  8. REByers
    REByers
    Dec 20, 2004
    12
    3
    Preston, Lancs
    Also does nayone know where I can get the IR tranceiver to change the channel on the digibox from my DVD Recorder? :confused:
  9. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    From the installation manual, code for PHILIPS DTR 1500 is 0327
    Mark
  10. GeorgeM
    GeorgeM
    Try connecting the tv out scart from the digibox to av2 in on the tosh as the vcr scart out is not rgb enabled.
  11. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    As well as GerogeM's suggestion, make sure that the AV2 input setting on the RDSX32 is correct (you need to set it for RGB, S-video, or Video (composite)
  12. REByers
    REByers
    Dec 20, 2004
    12
    3
    Preston, Lancs
    The plot thickens!!!! If I select the AV2 input I can see the freeview picture fine, it seems that the sat mon button may not be working OK on the remote!!!
    Also I've just noticed that BBC1 refuses to tune in on my box. Hay ho another problem to get to grips with!!! Also I've recorded several programs with video plus (and 1 manually programmed) and allways had the last 10 mins, or so, cut off. I've checked the clock on the Tash and it's correct, I just don't know why it's doing this?? Anyone got any ideas?
    Also, Any news on the IR transceiver to get the toch to change channels on the digibox?
    Thanks for all your input guys and gals!! :thumbsup:
  13. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Per my earlier post: From the installation manual, code for PHILIPS DTR 1500 is 0327
    Mark
  14. lurcher
    lurcher
    May 15, 2003
    4,114
    Stalybridge
    +202
    Mine took a couple of attempts to tune into BBC1.
