Tosh picture not horizontal
Discussion in 'TVs' started by Stinky985, Mar 5, 2003.
  1. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    Just got 32zd26 and all is fine except some broadcasts show the balck bars at the top and bottom of the screen. looking at this is shows the picture is not horizontal.It climbs slightly from bottom left. The picture is how ever parallel as the top shows the same.
    Is this Geometry and how do i sort it?
    I assume service menu then use the HSC setting to rotate it down slightly? then i can change the picture height in the normal menu.
    sound about right? this i what i can gather form the posts its taken ages to read!
    cheers in advance!
  2. Yugo1
    Yugo1
    The engineer took the back off mine and twisted the tube round till it was level. He told me you can't adjust it in the service menu.
    Yugo
  3. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    so did you just phone up the place where you got it? Or Toshiba directly?
    i ordered from Comet, but Toshiba delivered it.
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    If the deviation is less than 5mm they will say it is within acceptable tolerance.
