Tosh Picture Frame with Nicam Stereo?
Discussion in 'General TV Discussions Forum' started by The_kUrGaN, Jan 27, 2005.
  1. The_kUrGaN
    The_kUrGaN
    Nov 29, 2003
    377
    +17
    Think it's about time we upgraded our TV seeing as though we watch loads of DVD's and movies on Sky+.
    .......Apologies if this is a stupid question but is there a Tosh 32" Picture Frame TV with Nicam Stereo rather than DD? I'm looking to buy a 32" widescreen but only require Nicam Stereo as I already have an amp to connect up to it. Any recommendations? Budget will be £600-£800 and I'd like 100hz if poss and a couple of RGB scarts and/or some component inputs.
    Thanks for any advice
    Pioneer DV575a DVD Player.
  2. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Toshiba 32ZP46 has nicam instead of DD 5.1 which features on the 32ZP48 model.
  3. mcguire76
    mcguire76
    Only available from Currys, Dixons & occasionally Comet
  4. The_kUrGaN
    The_kUrGaN
    Nov 29, 2003
    377
    +17
    Thanks for the info. Is there any reason why it's only available there? Seems a bit bizarre.
    Also, cue another silly question. Is it possible on these TV's to switch between 50 and 100hz ?
  5. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Because most stores/internet shops went with the standard ZP48 model. DSG & Comet wanted a separate model to sell cheaper, So Toshiba provided them with a basic no frills version, the ZP46.
  6. mcguire76
    mcguire76
    The progressive scan mode is 100hz horizontal and 50hz vertical if I remember correctly. Active, Natural & 100hz are all 100hz, so technically it can't switch between 50 and 100hz.
    I have yet to see any artefacts on mine be it from Sky+ or DVD, before purchasing I too was weary of 100hz, however, none have appeared so far :thumbsup:
  7. BernieC
    BernieC
    Comet are currently selling the 32zp46p at £699.
    I bought the 36zp having had problems with a new Sony 100hz set and have to say that the picture quality and lack of pixelation is fantastic - I have tested on dvd, sky, terrestrial and on sport, movies and general tv.
    Basically, this set - and the easy choice viewing settings make this a 'must buy' set!
