Tosh Pic Frame 1 / 2 what is the difference?
Discussion in 'General TV Discussions Forum' started by Captain chaos, Jun 20, 2003.
  1. Captain chaos
    Captain chaos
    Can someone tell me what the difference (improvements) the Tosh Picture Frame 2 have over the original Picture Frame models?
    Thanks.
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    I haven't owned either tv, so I'm sure that there will be much more informed posts that this one to follow, but the basic differences are:-
    *PF2 offers progressive component inputs as opposed to the PF1 which only offered interlaced component inputs. With the right source connected, this option allows for a big step up in performance.
    *PF2 has an inbuilt line doubler to give the option of progressive scan on all sources, although internal line doublers rarely rival the performance of an external line doubler or progressive scan dvd player. PF1 has no line doubler and only offers 100hz processing.
    *PF1 was notorious for design faults (or "features" as Toshiba prefered to call them) the main one being that the sides of the picture were lighter than the middle, especially noticeable during dark scenes in films. The early signs are that the PF2 doesn't suffer from this problem, although there are reports that it is prone to green trails on moving objects. Whether this varies from sample to sample, ie. one set has it and another doesn't, or it's present on all sets, I don't know.
    The PF2 also offers a colour temperature adjustment, which the PF1 didn't.
    Hope this helps,
    Bob.
  3. Captain chaos
    Captain chaos
    Im sure the Pic frame 1 offered NTSC Progressive, not PAL prog though.
    Ive heard that the Pic Frame 2 does both PAL and NTSC Progressive.
  4. kwangomango
    kwangomango
    Jan 9, 2003
    859
    Kent
    +38
    No progressive at all on pf1. I think you are confusing it with the Strata model which does do NTSC progressive.
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    For all its faults I think my PF1 looks much better than the PF2, with its black screen surround.
    Should also be available a lot cheaper than the PF2
  6. kwangomango
    kwangomango
    Jan 9, 2003
    859
    Kent
    +38
    Cheaper cos its 2 years old.
    Stying of the pf1 is better but i personally think it looks very plasticky. pf2 is more solid looking.
    faults..faults don't get me started on faults. Anyone who spends over a grand on a tv should not be expected to put up with the faults on recent Toshiba units. The pf1 has more than most and pretty much all have been fixed on the pf2. The green trails are still there though, and personally that it not acceptable.
    pf2 has a newer tube and more features. As they say, you pays your money.....
