Tosh MT200 problem, dust?
dav076
Can someone knowledgable in pj's have a look at these pictures and tell me what is causing the discolouring above the word welcome, it is mostly noticeable on light scenes:
I've tried cleaning the lense with air, made no difference. Consulted the manual for tips and cleaning, this didnt help as the only mention of cleaning is the lense and the external pj casing. Have I got dust jammed inside the machine or is there something more sinister at work? The machines barely two weeks old. Any advice welcomed, this is my first projector :(
David.
Edit: Its not a mark on the screen either.
dav076
Its definitely a fault as it only appears once the projector has warmed up. When its first turned on the screen is completely clear.
