Quantcast
tosh hack
R
remfanuk
have read on this very forum that no toshiba dvds can be hacked...yet i have found a hack for the 100e dvd player. cant remember where i saw it..think it was a google search. i have yet to try it out cos i dont know if it will work and if it does will only have x amount of times to change it before it stays aligned to whatever region i last used. will put it on here if anyone is interested though i may try it first. just interested to see what people think of it.
BigRD
I have a Toshiba 230E and DR1. The 230E can be made multiregion by means of a firmware update on VCD. Have not had any success with the DR1 though.
Pejxa
The toshiba sd100 can only be hacked with a special data cable and special firmware. There is no remote hack.
