Tosh gone for repair
Discussion in 'General TV Discussions Forum' started by bazzae123, Mar 19, 2003.
  1. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    My Tosh 32ZD08B has finally gone for repair. Its had a intermittent audio fault from new but the Tube has now gone, well according to the engineer, as it has a very reddish tinge to it. I wrote a letter to Toshiba complaining about it as the set is only two years old and I thought this was a bit young for a Tube to go. Anyway, Toshiba said there would not replace the set but would supply a new tube free of charge as long as I paid for the fitting. Luckily the TV is under a warranty from the credit card company I used to pay for it. If you used a certain credit card you can register for a free extended warranty. Very useful. Well, I just hope the service centre can replace the tube and get it back to how it should be. Some how I don't think its going to be that simple.
    Has anybody had a new tube fitted without any problems?
    Bazza
