Tosh DLP and Sammy hd850
Discussion in 'General TV Discussions Forum' started by splash39, May 21, 2005.
  1. splash39
    splash39
    Feb 10, 2005
    25
    3
    nr Dover
    Hi all
    If any one has this combination or maybe the HD945 maybe you can help me.
    On setting up the sammy for the first time using HDMI i went into the menu and had the settings on HDMI/Comp on 1081 and RGB- Normal. It displayed the menu OK but would not display the DVD it flickered between a black/blue screen and no image. Getting slightly frustrated i switched off the TV and player at the plug and removed and replaced the HDMI cable in the back of the TV. BINGO! it worked everything played as normal with excellent PQ.
    After leaving the TV on standby overnight i switched it on along with the DVD player and i have the same problem again which is only resolved by following the same routine as above by switching off the TV and removing the cable. The same happens if i go into the menu and change the HDMI settings from RGB to Yc b R, no picture unless TV reset
    Any thoughts. Cheers all.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    May be worth experimenting with the switch-on sequence - DVD first or TV first...PJ :)
  3. splash39
    splash39
    Feb 10, 2005
    25
    3
    nr Dover
    Thanks PJ I will try that :thumbsup:
