Tosh DLP and Sammy hd850
Discussion in 'Blu-ray & DVD Players & Recorders' started by splash39, May 21, 2005.
  1. splash39
    splash39
    Feb 10, 2005
    25
    3
    nr Dover
    Hi all
    If any one has this combination or maybe the HD945 maybe you can help me.
    On setting up the sammy for the first time using HDMI i went into the menu and had the settings on HDMI/Comp on 1081 and RGB- Normal. It displayed the menu OK but would not display the DVD it flickered between a black/blue screen and no image. Getting slightly frustrated i switched off the TV and player at the plug and removed and replaced the HDMI cable in the back of the TV. BINGO! :D it worked everything played as normal with excellent PQ.
    After leaving the TV on standby overnight i switched it on along with the DVD player and :thumbsdow i have the same problem again which is only resolved by following the same routine as above by switching off the TV and removing the cable. The same happens if i go into the menu and change the HDMI settings from RGB to Yc b R, no picture unless TV reset
    Any thoughts. Cheers all.
