Tosh DLP AND HTPC - Help!
Discussion in 'TVs' started by whiteswan, Dec 8, 2004.
  1. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    HI
    As some of you know I have the Tosh DLP and am extremely happy with it.
    I have a pc (Last Aldi pc) - feeding it through the vga port on the rear of the tv and the pic quality is excellent.
    However is there any way of making the pc output 16:9 to the tv............I have the Medion 8083 pc.
    I get an excellent pic (especially hi def trailers etc) - but wondered if there was a way (using powerstrip perhaps) - of utilising the whole screen.
    What is 1:1 mapping - and how do i achieve it with this tv?
    If anybody is local to me in Chadderton, Oldham and wants to come and set it up for me - then offer away!
    Dave, Oldham.
    PS I will place this in HTPC forum as well...........
  2. Billy Hunt
    Billy Hunt
    Jun 29, 2002
    1,185
    Worksop
    +98
    Is it not just a case of selecting a 16:9 resolution in the graphic cards driver? (yours is the Radeon 9800 pro isn't it?)
    I doubt it's that simple but I always thought the Radeons were pretty good for displaying to a TV source.
    It is that simple with my Geforce I would just select a resolution of 1,280 x 720
  3. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    Where is the 16:9 option - I cant see one?
    Dave, Oldham.
  4. Number45
    Number45
    I've got a 9800XT, using the CAT 4.11s, and I can just select 1280x720 (Or at least I can once I get my TV), so yours should just be the same. :)
  5. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    Whats cat 4.11s?
    Dave, Oldham.
  6. Number45
    Number45
    Your graphics cards is a Radeon 9800, yeah? The ATI reference drivers are called Catalyst drivers (CATs), and 4.11 is the latest driver.
    It should be fine with pretty much any driver though. You just need to go into the Display Applet in Control Panel, into Settings and move the slider until it selects 1280x720.
  7. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    Right off i go to update the driver!
    Dave, Oldham.
  8. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    At the moment i dont have a 1280 x 720 option.
    You do mean when u right click on desktop and go into display properties dont you?
    Dave, Oldham.
  9. Number45
    Number45
    Yeah, if it's not there it's almost certainly because it's not supported by the current monitor driver. Try plugging it into the TV first, restarting then seeing if the option's there?
    The latest CATs are here, by the way.
  10. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    Right updated driver.........clicked on 1280 x 720 display option and screen goes blank - then 10 seconds later it reverts back to original setting and display returns!
    Help!
    Dave, Oldham.
  11. Number45
    Number45
    Do you have it plugged into the TV at the moment, or just into your normal monitor? The screen going blank is when it tries to run in the new resolution, and when it doesn't receive a response to its' 'Can you see this OK?' prompt it resets to the original configuration.
  12. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    I just have it plugged into the tv.
    Dave, Oldham.
  13. Number45
    Number45
    If you go into Advanced, and into the Monitor tab, does it show a monitor type in there? What's the refresh rate set to?
