Quantcast
Tosh 9500 bass management
Jase
It should have (if it's like my SD900). Pretty sure the settings are accessed when you select the 6CH Analogue option in the menu. Only thing is, for DVD Audio it completely ignores any settings you set (small/large) and passes full range signals to your amp (via the 6CH Analogue Outputs).
