Tosh 52wm48p scrathed screen and blue dot, help!
Discussion in 'General TV Discussions Forum' started by steveandlisabro, Apr 4, 2005.
  1. steveandlisabro
    steveandlisabro
    I have the Tosh 52wm48p, the sreen has a few scuffs on the surface. Does anyone know where i could or if i could have these polished out and where. Or wher can i get a replacement screen from?
    Also I have a pin rick of blue light projected onto the screen, is this just something on the projector thats needs cleaning off??
    Please help me :rolleyes:
  2. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    They might know something in the Projector screen forum,
    be carefull you don't make the problem worse trying to get rid of it.
    I have heard you can get the screen replaced i think it was Razor who knows about it.
  3. steveandlisabro
    steveandlisabro
    Is a dead pixel fixable?
  4. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    It would be a stuck mirror i'm surprised it's blue i would have expected black or white.
    i would be tempted to paint it black with a felt tip pen it might make it less noticeable.
  5. JZEE
    JZEE
    Jan 8, 2005
    If the blue dot you have is well defined, then I think it's probably a stuck mirror or perhaps a screen imperfection.
    Dust on the lens will usually look hazy and not defined to exactly a single position. With dust, you should still see the image being projected behind it.
  6. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    Hi steve & steveandlisabro
    There are companies out there that can sell you a replacement rear pro screen. If you are happy with the screens reflective properties etc then I would just contact Tosh for a replacement. If not you need a specialist av company that builds, designs for coroporate use. If you have no joy I might have a contact number for you. PM if you need a number. :)
  7. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    I don't see how, in a single DLP chip design, a stuck mirror could possibly produce any colour except white. Three chips are a different matter (but irrelevant here). Equally, I can't imagine what else may give rise to a blue dot. Strange.
  8. steveandlisabro
    steveandlisabro
    It is definately blue, the same colour as the light from the bulb!! also if there is no input into to the tv, ie if the screen is black I still get the blue light.Its about the size of a small knitting needle head.
    Could get an engineer out but dont want to be had !
    would I be able to fit the screen my self? and can I get just the top layer of the screen?
    Thanks for all your help!
  9. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    Would get an engineer out for the blue dot.
  10. LV426
    LV426
    Jul 14, 2000
    13,424
    +5,823
    Aha... stuck mirror, then. Not fixable except by replacing the entire DMD. You are at the mercy of whatever the manufacturer's stuck pixel tolerance policy is.
  11. steveandlisabro
    steveandlisabro
    Would a stuck mirror be easy to reapair?
  12. kourosh
    kourosh
    Feb 6, 2005
    14,618
    Portsmouth
    +1,045
    i wouldnt try anything :thumbsdow call the place where u got it from and let them sort it out cause as soon as u open the set yourself you will invaladate your warrenty and it may not even be the screen :confused:
  13. JZEE
    JZEE
    Jan 8, 2005
    What you're saying definitely points to a stuck mirror. When you're changing the DMD, try to get them to change the whole light engine because you may have picture adjustment issues when just swapping the DMD module.
    This really depends on your TV's design - I'm sure it can be done on the Samsungs.
  14. steveandlisabro
    steveandlisabro
    DMD ? sorry what is this . I have no warranty with the tv so to get this blue dot rid of, would this be really exspensive?
  15. g_unit
    g_unit
    Jan 4, 2005
    102
    16
    Scratched screen, no warranty... sounds like a back of van jobbi to me!
  16. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Digital Micromirror Device or Digital Micromirror Array
    Try a felt tip pen black is less distracting than a bright blue or maybe a tiny bit of matt black tape
  17. JZEE
    JZEE
    Jan 8, 2005
    No warranty???? :rolleyes:
    Well this can potentially cost you quite a bit to repair then. An entire light engine would usually cost somewhere in the region of about £1300 and once again, depending on the TV model.
    Perhaps St_ve's recommendations make more sense :confused:
  18. DLPCurious
    DLPCurious
    Sure this set was purchased through Ebay. Pretty sure seller stated screen was scuffed and had dead pixel. Amazed anyone bought it actually. Sure they paid in excess of a Grand for it. Not a bargain with those kind of defects really.
