The MRP is 399 Euros which works out about £265, so its realistic that the on-line price could be 20% below this. Multi-region via firmware update usually adds about £10-20 doesn't it (e.g. richer sounds 220E)?
Looks like great value, but according to Timh's post re. Toshiba's PAL Prog plans, it doesn't sound like an upgrade will be available.
However it does have high resolution/ Hyper AntiAlias filter and despite my probs with the 220E, I'm tempted to swap my Pioneer 656 for one of these.
Just got a reply from RGBdirect. They've just got some in and they're £ 220 with Multiregion.
Just going to place my order now.
It says they are progressive scan on rgb's website.
Just got off the phone should be here before Friday.
One other thing though on the phone they do charge £10 delivery.
Just got back from richer sounds in liverpool they will be selling the 520 for £299 very soon. The guy i was speaking to said that they had 1 in but it was not multi region.
Thanks for that i've gone for the Ixos 171AV.
I got them from www.homecinemaheaven.com for £29.95 though I only needed 2m or less so 5m would be a bit of a waste, saved £10 into the bargain.
Thanks again for the info.
I bought the Toshiba 32ZD26P about two weeks ago, have to say I'm very impressed with the quality of the picture and the tv as a whole.
Would have liked the 36" version but couldn't really push it to the extra cost.
I know what your saying, however i was quite lucky as the tv is getting bought for me by my dad as a wedding present. Plus QED are selling it for £1533.89 which helps.
Have you any idea what the 510 went for when that was first released. I still cant get my head around why the 520 is so cheap.
I'm not sure what the 510 went for when it first came out, but it's been around £300 while I've been thinking about getting one. I've seen some RRP in some mags of £399 but they're normally way out.
Got a very nice surprise when the 520 came out at that price, I was expecting it to be more than the 510.
Hi, Andy thats a super price for the tosh, please let us know what the Pro scan is like m8, I'll hang on untill Monday before I place an order if its "excellent" which I'm sure it will be,
If you go for the 520 I would reccomend conecting it with component cables then you'll get the advantage of progressive scan on your region 1 dvd's.
you should be able to connect both sat box via scart leads, but if I remember correctly only the first scart socket is RGB enabled.
