Tosh 520 and Prog San with component
petrolhead
Have a couple of questions.
Have the Tosh 520e and now got a couple of region 1 DVDs.
My next step is to go component.
Will I notice a difference? Why I ask is that when viewing R1 thro Svideo and comparing the same DVD R1 and R2 I find the R2 is much better.
Which type of component cable? I have the choise of either 3 separate leeds or 1 loom. I would rather go the loom route as it is less bulky.
You views and thought would be a great help
S
Samir
Hi Petrolhead
When you step up from s-video to pro scan the difference is amazing. DO IT NOW:devil:
For component cables you can use muti-core or seperate cables they should be 75ohm video co-ax.
I just can't wait for ATOTC in pal prog scan
Samir
petrolhead
That was an enfatic YES!!
Pal Prog Scan - You hope - which player?
S
Samir
My Denon 2800 MK 1 runs both NTSC and PAL prog scan and It doesn't suffer from the lip-sync problems that some people had.
:D
Samir:)
