CSGardner
I would like to know if the Toshiba 510 is able to output both RGB from the SCART as well as COMPONENT (from the compnents output obviously) - iwhtout having to select change the settings ?
(I ask because with others I've checked on - e.g. Sony NS900 - you have to choose between RGB on SCART or COMPONENT out ... and I prefer to not have to keep changing the setting).
I'm considering new player options, where I can use RGB out to the TV, or COMPONENT out for projector use.
Thanks for any info,
Chas
Chas
