TOSH 46WM48 with Pace Sky+
Discussion in 'General TV Discussions Forum' started by sheppy, Feb 28, 2005.
  1. sheppy
    sheppy
    Jan 26, 2003
    49
    North East
    Can anybody with a Pace v2 Sky + box plz help me?
    If you put a channel on that just has the search and scan banner does the picutre flicker to one side every few seconds or so?
    I've had a Sky Engineer with me on Saturday and Monday and we have gone through 4 Pace boxes and each of them showed the same trait!!
    This did not happen with the amstrad one I had previously
  2. supermackem
    supermackem
    Feb 20, 2005
    2,167
    sunderland
    +91
    Yep mine does the same mate i a have a pace version 2. Im glad its a problem with the sky box and not the tv. As everything else is faultless in component vga etc.
  3. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Iv'e just had an Amstrad Sky+ box installed (yesterday) and fortunately I don't appear to be suffering the banding problems recently discussed on this forum. :thumbsup:
    However when tinkering with the settings I did notice that when I set the output from the box to RGB the banner did almost constantly flicker. Set to PAL there's no problem at all.
    :confused: Just tried to replicate that problem and it's now fine on both RGB and PAL. Sorry!...........It definately did it yesterday.
  4. supermackem
    supermackem
    Feb 20, 2005
    2,167
    sunderland
    +91
    Hi mate are you using a scart switch box by any chance. I use a joytech one and have just removed it from the chain i now have all things going into the tv and it has removed the lines i was getting.
