darkan9el
Established Member
Hi all, thinking of taking the plunge and buying the Tosh 46WM48, I dont have sky or cable, just the straight bog standard 4 channels, but I watch a lot of DVD's and may consider Freeview if I can find out how to get it in NG18. I have been told not to use the notts signal and go for another but its all gobble'de'gook to me.
Best regards Lee
- So would this be a good TV to watch DVD's on.
- Also; is this any good with PSX games both 1 and 2.
- Would the bog standard Anologue channels be Ok to watch should I get an urge to do so.
- Is there anything else I need to buy with this TV
Best regards Lee
