Tosh 46wm48 connections
Discussion in 'Televisions' started by Hooch100, Jul 29, 2005.
  1. Hooch100
    Hooch100
    Hi everyone
    been reading your posts for a while now and got some very good advice so thanks for that! My question is an easy one I think,,I have a pioneer freeview box which is connected via the rgb slot on the tv..The picture is almost very watchable but i do get "oil painting" faces one and a while,now i've read that connecting via composite will give me a better picture is this correct? I don't want to spend £50 of my hard earned cah on something thats not going to work!! any advice would be gratefully acted upon.
  2. Mark_a
    Mark_a
    May 27, 2005
    2,831
    +469
    I suspect you mean component, rather than composite. To be honest I very much doubt you'll see any real difference. Component and RGB are so close as to more or less indistinguishable. Now changing to a progressive feed over component may well yield some benefit, but your DVD player has to be capable of progressive output. Many aren't, so make sure you check that out before buying something.
    Regards
    Mark
  3. Tufan
    Tufan
    Hooch100, what is your DLP model?
  4. supermackem
    supermackem
    Feb 20, 2005
    2,060
    sunderland
    +71
    No freeveiw box is capable of outputting a prog scan pic alough the component would look a tad better than scart it would be worth anywhere near the price of a decent lead. Best of sticking with the rgb scart lead.
  5. Hooch100
    Hooch100
    Toshiba 46wm48
    Yes I did mean componant sorry bout that...ok I stick with the RGB I did get a decent QED one and it has made a difference..thanks
