Tosh 46WM48 and HDMI 'problem'.
Discussion in 'TVs' started by Vandal, Dec 21, 2004.
  1. Vandal
    Vandal
    Dec 19, 2004
    267
    28
    +40
    Hi all,
    First post, but have been lurking for a while and wanted to first say thanks for all the advice and info I have picked up off the forums. :thumbsup:
    I received the Tosh yesterday and have it paired with a Denon 2910.
    The picture quality from RGB scart is stunning I have to say, albeit at the limited resolution.
    When I switch to HDMI (720p or 1080i) the picture looks 'washed out', that's the only way I can describe it. For example in Star Wars Episode 1 in the Pod Race scene there is a haze, which almost looks due to lack of colours somehow..
    In Finding Nemo, if I switch between scart and HDMI the colours are nowhere near as vibrant on the HDMI.
    I am wondering if there is something I am missing here or do I have a faulty HDMI input.
    A quick rundown on the set:
    It looks fantastic and the display is pin sharp. Even Sky looks much better than I was expecting. Tried my PC through it and again pin sharp - very impressed.
    Looking forward to running the XBox through it :D
    Cheers,
    V.
  2. Carl_Docklands
    Carl_Docklands
    Vandal - if you have not fixed this make sure your play with your picture settings as the ones out of the box are nowhere near optimal.
