Tosh 46WH08B Stand Size?
Discussion in 'General TV Discussions Forum' started by logiclee, Nov 11, 2001.
  1. logiclee
    logiclee
    Aug 9, 2000
    1,662
    116
    Notts, UK.
    +710
    Hi All,
    Does anyone have the Toshiba stand with the 46WH08B?
    If so I'm after the overall hieght of the stand and the size of the hole behind the glass door. (hoping to fit a centre speaker in the stand)
    Lee
  2. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    There are two glass doors meeting in the centre which open outwards. There is a support in the centre of the space inside the cabinet so you cannot place a centre speaker there. There is ample space either side for other components though. The stand is approx. 25cm high.
