Tosh 46 Stand Problem
Discussion in 'General TV Discussions Forum' started by bassett, Feb 10, 2005.
  1. bassett
    bassett
    Nov 26, 2004
    Has anyone found that they cannot put the swivel corner of the stand in its correct position?
    I have just assembled my new 46WM48 only to discover that the bottom right corner of the TV prevents the hinged corner of the stand from closing - it has to stay open. I tried pushing it into position and this pulled the screws out of the back of the hinge. I'm gutted and puzzled :confused: I have definately assembled the stand correctly. Just spoke to the dealer I bought it from and he hasn't heard of this problem. I can see that I will be able to adapt this by cutting half an inch of the swivel part of the stand but I shouldn't have to do that.
    Anyone??
  2. mdekkers
    mdekkers
    Dec 5, 2004
    75
    nope - mine fits perfectly....
  3. soni
    soni
    Oct 22, 2004
    557
    Kent
    I had a problem fitting the left post into the bottom wooden shelf, spent about an hour on that post alone, i think there was a problem with the screw holes not lining up right, as each time i screwed it in there was a massive gap visible in the joint, it just looked so obvious that it wasn't sitting at the correct angle, anyway i handed it over to the Mrs in the end, and within 5 minutes she had it soughted PERFECTLY - i hate women!
  4. dbisping
    dbisping
    Dec 14, 2004
    42
    No Problems with mine, I did have one of the locking screws that would not lock and took me ages to fix it, other that that it's fine
    Dave...
  5. albertz
    albertz
    Sep 19, 2002
    347
    Newcastle upon Tyne
    +21
    are you sure the tv is sitting correctly on the stand? if the right "wing" isnt secured with the long wood screw it may be out of position, ensure that the locking bolts are screwed in tight, as if their not it may be at an angle and push the wing out of true.
    i did have problems with the right back post, it wouldnt lock properly, but putting a bit of weight on it soon sorted that!!
  6. fleagledog
    fleagledog
    Dec 31, 2004
    61
    This stumped me for ages until I realised that the TV sits forward of the stand. Then it fits perfectly.
  7. bassett
    bassett
    Nov 26, 2004
    Fleagledog, are you sure its supposed to sit forward of the stand?
    The picture in the brochure has the front of the TV lined up with the front of the legs.
    I've now planned 10mm off the inside of the hinged 'bit' where it was striking the TV and it now fits. Every other aspect of the stand and its assembly was just fine.
  8. fleagledog
    fleagledog
    Dec 31, 2004
    61
    The pictures are misleading. That's what I thought. However, mine is set up with the speakers lining up (actually very slightly forward) with the vertical stand pillars. This puts the center part of the TV about 10mm forward of the stand. See picture here; it looks flush from the front.
    http://www.avforums.com/forums/attachment.php?attachmentid=10045
  9. dbisping
    dbisping
    Dec 14, 2004
    42
    Thats the same as I have it as well, I think the rear of the screen and the stand line up perfectly then and you should be able to get the retaining strap affixed
    I think when you have lined up the little plastic semi-circle thingys in the stand with the bottom of the Tv it locks it inplace too
    Dave...
