Tosh 46 dlp weird noises
Discussion in 'General TV Discussions Forum' started by skip, Apr 5, 2005.
  1. skip
    skip
    Jan 17, 2005
    108
    my tosh as started making what i can only describe as loud cracking noises every now and then while i am watching tv, also the tele text as started not to respond while i put page numbers in and then respond after about 2 to 3 goes. is the writing on the wall or is this normal for this type of tv.
  2. Razor
    Razor
    Dec 15, 2004
    37,563
    2
    +12,432
    Writing on the wall. Get it seen to.
  3. skip
    skip
    Jan 17, 2005
    108
    looks like i am of to the mighty costco then and see how good there warranty is
  4. Razor
    Razor
    Dec 15, 2004
    37,563
    2
    +12,432
    You should be fine, from what I have heard Costco is good at returns. :)
  5. -TYN-
    -TYN-
    Nov 23, 2004
    607
    28
    +29
    This is when you will realise how much of a good idea it was to buy from Costco.
    They basically just said to my brother do you want it exchanged or a refund and that was that, simple.
    He even said at first i might exchange for a different brand, and they said well we will just refund you and you can take alook. How refreshing.
    Let us know how you get on m8.
  6. skip
    skip
    Jan 17, 2005
    108
    will do, thanks for the replys. problem now is do i try again with the tosh or jump ship and go for the sammy 50
  7. supermackem
    supermackem
    Feb 20, 2005
    2,093
    sunderland
    +78
    Mine make s these craks also, i dont know if its coming from tv or stand.
  8. whiteswan
    whiteswan
    Dec 9, 2002
    940
    Oldham
    +54
    Hi Mine does too!
    But i solved it - its the cabinet/stand when temp in the room is increasing or dropping - nothing to be worried about.
    Dunno about the teletext thing though.....................
    Dave, Oldham
    Hi everyone - how the hell are ya by the way?
  9. skip
    skip
    Jan 17, 2005
    108
    how did you resolve the cracking noise. i have stood by the set and it does seem to be coming from the tv as it seems to be getting more frequent now.
  10. schnipps
    schnipps
    Jan 6, 2005
    117
    16
    There is something wrong with your set skip, the cracking swan is on about is furniture noise youe get from temperature changes, probably happens once or twice on an evening and comes from the casing/stand area. If you think its coming from the tv and it happens freqently then there is no way i would be leaving it unseen to
  11. skip
    skip
    Jan 17, 2005
    108
    cheers schnipps, will do the problem is you have to take it all apart and take it back to costco,they dont as far as i know have a repair division.
  12. albertz
    albertz
    Sep 19, 2002
    346
    Newcastle upon Tyne
    +21
    if its comming from the set, it could be a serious problem, but bare in mind that these sets have a large but thin plastic back, that will crack with changes in temperature, mine cracks a couple of times after being switched on, but then nothing. does it affect the picture?
  13. Razor
    Razor
    Dec 15, 2004
    37,563
    2
    +12,432
    No it shouldnt do, all that is happening is that the case is expanding as it gets hotter, it will do the same when it cools down. Totally natural and nothing to worry about all tv sets do it.
