tosh 42wh36
Discussion in 'General TV Discussions Forum' started by stormyuk1, Nov 22, 2003.
  1. stormyuk1
    stormyuk1
    ive just bought the toshiba 42wh36 rptv and running it off the back of my arcam fmj dv27 via component i am getting stunning results! however, i do have a problem that someone can hopefully advise with. when the screen is very dark to black, im getting a vertical black band, darker than the rest of the screen about halfway across the set. any ideas?
    replies much appreciated!
  2. Skull Cowboy
    Skull Cowboy
    I’m probably not going to be much help, as I haven’t actually got one of these sets! However, I hope to be getting one soon and have done a bit of research on the xxWH36 range using these forums. Other people have mentioned a band about 1” wide on these sets which has been attributed to masking tape residue. I’m not sure if this is the same problem that you’re having but do a search for ‘masking tape’ to find the relevant threads.
