Tosh 42WH18B Built in Sound?
Discussion in 'General TV Discussions Forum' started by sarll, Apr 11, 2002.
  1. sarll
    sarll
    Mar 19, 2002
    1,393
    63
    +126
    I've been thinking of buying a 42WH18B but have a couple of questions. After buying the set i will have to save for a few months to buy a decent amp and speakers. 'Out of the box' what speaker set up is provided on this set? I understand it has 2 rear speakers supplied, but what about centre/left/right and subwoofer? Are they built in? Bascially i want to know if, out of the box, i am going to get a reasonable dolby digital surround sound experience....
    cheers for any thoughts
  2. matt janes
    matt janes
    I've got the 50" which has the same internal amp and speaker set up. Whilst I have separates , I have tried the set using internal amp and speakers and it's remarkably good. It's dolby digital. You'll be impressed!!
  3. Guest
    I have the 40" Dolby Digital version. Terrible audio. So bad I forked out for an AV amp a few days later and bought a centre channel. Great pix, but VERY weak audio from the two small built in's that kiss the floor.
