Quantcast
tosh 42pw23
R
rulett
hi all,i got a tosh 42pw23 about a month ago.all was fine until about a week after when i noticed a faint red tinge about a third of the way in from both sides.anyone else had this problem?
sounds like the convergence has slipped. have you adjusted it the menu?
R
rulett
i have but not latley,i'll try it again and let you know if it helps.thanks.
ok, thanks. my 23 is doing my head in what with the convergence, already:lol:. i've also noticed that where you view the tv from affects convergence aswell. so if you ajust from one seating position it will be out for another seating position.
blackadder
weyland-yutani-
Been looking at the tosh 42pw33 in currys and thought it looked pretty good but reading about all the problems setting convergence is starting to put me off,is it true that if its set for one seating position it will look out in another or is this just on your set.
This buying a new tv is doing my head in :suicide:
R
rulett
i must say the tosh 42pw23 is a great tv, and size, for the price right now.i have adjusted the covergence again and it does seem a little better regarding the red tinge.one important factor before buying this type of tv is your viewing distance.too close does not do it justice,at least 8 ft in my experience.if you are thinking about buying this type of tv i have no hesitation in recommending them.
Similar threads
