Tosh 42pw16...panny tuner??
Discussion in 'Plasma TVs' started by V5-APS, Dec 23, 2002.
  1. V5-APS
    V5-APS
    May 7, 2001
    637
    London
    +10
    Hi there....does anyone know if the Panasonic tuner box will work with the Toshiba 42PW16.....as i am told the Toshiba is the Panasonic 42PW5 in a thinly veiled disguise!!
  2. prusling
    prusling
    Sep 17, 2001
    74
    Poole, Dorset, UK
    ...and I believe that the tuners are different between the 4 and 5 series.
    Cheers, Peter
  3. V5-APS
    V5-APS
    May 7, 2001
    637
    London
    +10
    Does anyone know for sure if the newer tuner and terminal board will or will not fit and work with the older 4 series?
