Tosh 42" Setup..
Discussion in 'General TV Discussions Forum' started by micflair, Dec 28, 2001.
  1. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Okay, getting my Tosh 42" tomoz.. just need a bit of advice..
    How long should I leave it on for before messing around with it? whats the first thing I should do with it? any advice really!!
    Dont wanna blow it straight away :)
    Mick
  2. Guest
    Go my 42wh18b last sunday and think it's brilliant :)
    The advice seems to be to let it warm up for about an hour before playing around with convergance etc. But it's worth doing and only takes a few minutes in the user menu. Haven't got round to looking at the service menu yet (need a quiet couple of hours on my own for this I think).
    One main thing is to make sure you reduce the contrast setting as they seem to arrive on setting of 100 from factory :eek:
    Got mine on about 42. If you do a search for this model no on here you'll get loads of advice tho.
  3. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    Try a search on the forum for your model of tv and you will find plenty of comments re these subjects.
