Tosh 37wl56 Stand question
Discussion in 'Home Cinema Buying & Building' started by Soapysoap, Sep 24, 2005.
  1. Soapysoap
    Soapysoap
    Dec 23, 2004
    52
    Hi, Ive ordered a Tosh 37wl56 with stand. If anybody has one could you let me know the dimesions between the shelves or where I can get the info (tried tosh website to no avail) as I have quite a large amp that needs to fit in. Any help would be appreciated
    soapy
  2. joon79
    joon79
    Aug 1, 2005
    37
    Shrewsbury
    +3
    I too would be interested in this info if anyone has it - couldnt find anything on the web either! maybe an idea to ring toshiba direct....
  3. BLOWNIT
    BLOWNIT
    Apr 24, 2005
    34
    Working from bottom to top,
    From the Top edge of the bottom wooden shelf to the underside of the first glass shelf is 5 1/2 inches.
    From the top edge of the first glass shelf to the under side of the second glass shelf is also 5 1/2 inches
    Lastly from the top edge of the second glass shelf to the underside of the tv is 5 3/4 inches.
    These are approx as my hypervalue tape measure is not calibrated.
    Hope this helps,
    BLOWNIT
  4. Soapysoap
    Soapysoap
    Dec 23, 2004
    52
    Thanks Blownit, 51/2 inces is about an inch too small for my amp so guess I'll have to have aseperate cabinet.
    Thanks again
    Soapy
