Tosh 37C3035 or 37X3030 or Samsung LE-37R87BDX
Discussion in 'Samsung TVs Forum' started by rj73, Jan 17, 2008.
Tags:
  1. rj73
    rj73
    Hello All
    I have finally decided to go for a 37" LCD instead of Pana 37" plasma. I couldn’t see any reviews for 37C3035 and in Comet it is expensive than 37X3030 and 37C3030. One of the threads says that the only difference between 37C3030 and 37C3035 is s/w. I am bit confused whether to go for 37C or 37X and all I wanted is, to see my sky+ stuff (SD) better than my existing Tosh 27 NON-HD LCD Tele.
    Tosh 37X or 37C, which is more preferred for sky SD?. If Samsung 37R87BDX is better than Tosh for sky, then I will go for it though I prefer Tosh.
    Thanks for the help
    Rj73
  2. rj73
    rj73
    Help please
  3. varkanoid
    varkanoid
    Jan 6, 2006
    635
    46
    +104
    nearest I could find was http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=7357
    www.digitaldirect.co.uk have them in for £501 which is a bargain, ordered one!
  4. PeaJay
    PeaJay
    Dec 7, 2004
    171
    +15
    A bigger review from the same site...
    http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=7436
    The 37X3030D gets a cracking write up, and a "Home Cinema Best Buy" rating, so can't be bad!
    I can attest that this is a fabulous TV too - having got one from Amazon late last year for a little less than they are selling them for now (sorry). Its also more than you can get the 37C for... So, you need to think, do i want that full HD panel for a little more, or can I settle for a HD ready panel and pocket the difference :cool:
    http://www.amazon.co.uk/Toshiba-37X..._sr_1?ie=UTF8&s=gateway&qid=1200992338&sr=8-1
  5. rj73
    rj73
    Thanks for the suggestion. I finally bought 37X3030D from Currys for £650. I will get it this weekend.
    Thanks again
    rj73
  6. varkanoid
    varkanoid
    Jan 6, 2006
    635
    46
    +104
    My Tosh 37C3035DB arrived this morning and I am well pleased with it.
    It was way too bright so I followed another thread for setup of brightness etc for the 40" Tosh and they work fine for the 37C3035DB.
    (not the service menu settings just the picture settings etc) :thumbsup:
  7. mkkbb
    mkkbb
    May 21, 2006
    10
    Does anyone know what the difference between the 37X3030D and the 37X3031D are?
    I have seen the 3031 in Tesco for £649, but not sure if it is any different to the 3030 I have just bought. If it is better I can return the 3030, no problems.
    Any feedback appreciated.
