tosh 36zp18q
N
normski
hi all out there
anyone know if it is possible to correct poor convergence on this tv the engineer says it cannot be adjusted as it is pre set in the tube at the factory as you probably know this tv is not a true flat screen you can see the curved tube behind the front face plate glass so this convergence should be better then a true flat screen your advice please
thanks
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
