Tosh 36zp18q
Discussion in 'General TV Discussions Forum' started by gallus23, Jul 2, 2002.
  1. gallus23
    gallus23
    Jun 30, 2002
    65
    Godmanchester, CAMBS
    I know this is very subjective but does any does any one know what the Tosh 36ZP18Q (picture frame set) is like to live with ?
    I've been lusting after one but its a lotta cash . . . .
  2. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    702
    Norwich
    +11
    there are several (very) long threads regarding this set, if you care to search for them.
    You'll find that the set has half a dozen or so inherent faults (such as lighter sides, dirty screens, flickering contrast/brightness, even rattly subwoofers i think!).
    Would be worth your while checking the threads out carefully, before making your decision.
    I too considered this set for a while, but was soon put off by the information i found here. Went for the Philips 36Pw9607 instead, which I am thrilled with.
    Matthew
  3. gallus23
    gallus23
    Jun 30, 2002
    65
    Thanks for the advice I'll have a dig around...
  4. Doubledoom
    Doubledoom
    However, the massive majority love the Tosh so remember that when you read them.
  5. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    Not sure what you mean by what is it like to live with?
    It's a dam site easier than the missus,no mood swings,never asks for money and never moans if I go out.
    On a more serious note the telly is superb the only fault my Zp18 has is the darker edges(not light?)but only on certain things and that is a minor niggle.
    It does not actually look like a 36inch set as there are no speakers either side of the cabinet it cuts down drastically on the size and is very pleasing to the eye.
    I am very happy with my set although I may be parting with it due to the Prog Scan capability of the new Toshiba.
    I say go and get one as I and many other people are very pleased with it.
